21611 Discussions
ARRIA V 1.1VCC issue
I have designed a new board for my company based on a 5AGXMB1G4F31C4N.
When I received the board, I checked isolations between all the power line and GND. I got a 35Ohm isolation between VCC 1.1V and GND.
I'm looking for what appened : power pins connexion seems to be OK.
Could you please help me ?
Despite those problem, I managed to configure the FPGA NIOS2 + Uniphy DDR3 + JTAG + EPCS + FLASH running uClinux
Thanks in advance.
It doesn't sound like you have a problem. If you can configure the FPGA and perform the tasks you've stated then a lot is working properly.
35Ω is a perfectly reasonable DC resistance to measure between VCCINT and GND on an assembled board. What were you expecting?
A quick check on some boards I have around me reveals DC resistances as low as 20Ω between VCCINT and GND. They all work as expected.
Cheers,
Alex
Thank you...
I was expecting values like Mega Ohms...
