21615 Discussions
Ability of Cyclone IVE to do floating point arithmetic
ryangjoraas
Hi -
I am using a Cyclone IVE FPGA currently and would like to know recommended ways for it to do floating point arithmetic?
I was originally thinking of implementing a Nios II core, but because the Nios II is obsolete and its IP can't be purchased anymore, are there any other ways to do floating point arithmetic with a Cyclone IVE FPGA?
I understand I could implement a Nios V/g core, but the Cyclone IVE does not support a Nios V core.
Ryan
FvM
according to Nios V reference manual, V/g can be implemented with Cyclone IV E.
See table 69, performance benchmark.
Technically, there's no reason why Cyclone IV shouldn't be supported because logic core of Cyclone IV, 10 LP and MAX10 is the same.
ryangjoraas
Hi - Thanks for the message.
I do have one last question - per the performance benchmark table, do I need to use the Quartus Prime Standard or Pro edition to build and compile my project or can I use the Quartus Prime Lite edition?
JingyangTeh_Altera
Hi
NiosV is supported for the CycloneIVE that you are using.
You could refer to the table below:
https://www.intel.com/content/www/us/en/docs/programmable/778829/current/software-support.html
For the NiosV benchmark there is a summary on the difference located here:
https://www.intel.com/content/www/us/en/products/details/fpga/intellectual-property/processors-peripherals/niosv.html
Basically regardless of which Quartus you are using Standard or Pro. The NiosV c m g core are available.
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any more follow up question regarding this?
Jingyang, Teh
ryangjoraas
No, I don't.
JingyangTeh_Altera
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
