21615 Discussions
About "alt_flash_open_dev" and CFI table
hi, when i use function "alt_flash_open_dev" to open a CFI, i can't get the correct base address which i set in SOPC. and i'm sure i have already include the relative head files.I don't know why.And it tips no CFI table found at base address when i use flash programmer in NiosII. And i used command "nios2-flash-programmer --base=0x0 --debug",it rise following messages: please see attachments. thanks for any suggestions you will offer.
which head files did you include?
hi,oucchina.i include following head files in my program. what's yours?
# include "system.h"# include "sys/altera_avalon_pio_regs.h"# include "alt_types.h"# include "sys/alt_flash.h"# include "sys/alt_flash_dev.h"# include "stdio.h"# include "string.h"# include "altera_avalon_cfi_flash.h"
hi,
i include all of your, only have not the "#include "altera_avalon_cfi_flash.h"", is this head file is necessary? if have not this head file, is the system all right?
can you open the cfi_flash device in the program, when process cure?
no, i'm now very boring with it. i set my reset vector in flash and other files and vectors in sdram, but the flash handle can't return the right value which i set in SOPC.
hi,
otis, i have the same question as you, when debug it, it can return the right value --not NULL, but when i download the flash file into flash, and run the system, the nios program can not open the flash, and returns the wrong value---NULL.
hi,
I have the same problem. If you solved the problem, I want to know the way of solution.
--- Quote Start ---
hi,
--- Quote End ---
in version7.0, it was automatically solved for you. And I got stuck in other versions.
--- Quote Start ---
--- Quote End ---
Hi otis,
thanks for reply.
I am using 8.0 now. I think that I will use i2c eeprom instead.
I have seem problem. I use 7.2 version (Cyclone III development board). Please, any idea.
Thank you
Rosa
