Programmable Devices
21611 Discussions
Address alignment problem with Tristate Controller
Hi all,
I have a Generic Tristate Controller and a custom Tristate Controller interfacing two external devices via Tristate Pin Sharer. Both external devices have a 16bit data bus, therefore address[0] pin from Pin Sharer is not externally used, so in my top-level file I use:
flash_lan_addr <= flash_lan_addr_local(flash_lan_addr_local'high DOWNTO (flash_lan_addr_local'low +1));
This worked fine while having two Gerneric Tristate Controllers, but with my custom Controller, I get a pointless error during Partition Merge:
--- Quote Start ---
Error (35030): Partition "fpga_sopc:U_1" contains I/O cells that do not connect to top-level pins or have illegal connectivity
Error (35032): Output port "fpga_sopc:U_1|tristate_bridge_tristate_bridge_address[0]" on partition "fpga_sopc:U_1" must drive a top-level pin but is driving "<nothing>"
--- Quote End ---
Of corse address[0] is driving nothing, there is nothing to drive!
I need help, what's the problem here?
My TCM Interface looks as follows:
tcm_data_in : IN std_logic_vector (15 DOWNTO 0); tcm_grant : IN std_logic; tcm_address_out : OUT std_logic_vector (7 DOWNTO 0); -- Byte Address, Bit 0 is not used tcm_chipselect_n_out : OUT std_logic; tcm_data_out : OUT std_logic_vector (15 DOWNTO 0); tcm_data_outen : OUT std_logic; tcm_read_n_out : OUT std_logic; tcm_request : OUT std_logic; tcm_reset_n_out : OUT std_logic; tcm_write_n_out : OUT std_logic
Simon
Scanning the report, I found these additional messages:
--- Quote Start ---
Info (35026): Attempting to remove 2 I/O cell(s) that do not connect to top-level pins or have illegal connectivity
Info (35028): Failed to remove I/O cell "fpga_sopc:U_1|tristate_bridge_tristate_bridge_address[0]~output"
Info (35027): Removed I/O cell "eth_top:U_10|tcm_address_out[0]~output"
Critical Warning (35033): Found I/O pins in lower-level partitions that are not connected in the top-level design
Critical Warning (35034): I/O cell "fpga_sopc:U_1|tristate_bridge_tristate_bridge_address[0]~output" is not connected to partition "fpga_sopc:U_1"
--- Quote End ---
This seems, like the Synthesizer recognized my custom TCM not using address[0] and therefore removing it, while failed to remove address[0] from the generic TCM (for whatever reason). Maybe this divergence causes the problem...
I managed to get around this problem, by connecting address[0] to a spare pin... but honestly, this is no real solution :mad:
I found the problem myself:
I had the setting "Ignore partition assignments during compilation" off, while my custom TC was in a different partition as the gerneric TC. Therefore optimization of address[0] failed :rolleyes:.
Simon
