21602 Discussions
Advantest / Jabil Penang _Reject part returns under FPGA - MPN: 10M16SAU169C8G - 7pcs
Junyi_yap
Hi Intel folks, @Farabi
Jabil Penang manufacturing line found 9pcs MPN: 10M16SAU169C8G FPGA component with failure symptom - measure 3.3V, LLD measured as 12.5 ohm expected 600ohm.
Please kindly advise how are we going to perform the reject parts return.
Its urgent case. Need response ASAP.
Will share the Device Problem report in short while.
Farabi
Can the devices programmed successfully?
regards,
Farabi
Junyi_yap
Hi @Farabi ,
All 7 pcs FPGA fail to reprogram.
Please kindly refer to attached DPR.
NurAiman_M_Intel
Do you see any error message? Can you provide the screenshot of the error message?
Aiman
NurAiman_M_Intel
  • As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
