- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi INTEL teams,
I am electrical electronics engineering student my advisor asked me to design a communication module based in FPGA from INTEL,
According to my advisor the Communication module that i have to develop should connect to Ethernet based communication systems via the RJ-45 connector (100Base-TX) and the fibre optic LC connector (100Base-FX). The protocols that I will implement will be only DNP3 , GOOSE and MODBU.
I have no any experience with developing FPGA before , Which FPGA development board should I use?( I need an affordable board because I'm an student )
And to design an communication module using intel’s FPGA which programing language should I learn ?
"My sir said he has used
İNTEL ALTERA 5CGXFC7C6F23I7NQS before and he said that I can use it or any alternative with same specifications like this FPGA"
Is there is any İNTEL ALTERA 5CGXFC7C6F23I7NQS development board available?
Please guide me
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Link below listed the available FPGA development kits for all FPGA families.
https://www.intel.com/content/www/us/en/products/details/fpga/find-fpga-boards.html#sort=%40title%20ascending
The Arria V GX FPGA Starter Kit has RJ-45 connector and support Ethernet based communication.
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/v-gx.html
Application Note AN647 below showcase the Triple-Speed Ethernet example design.
https://www.intel.com/content/www/us/en/docs/programmable/683344/current/single-port-triple-speed-ethernet-and.html
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for your replying,
I checked up The Arria GX FPGA starter kit and unfortunately it is not available on any market and also its very expensive, I need only and FPGA like this one
and also I see in this FPGA on Mouser that is saying
Number of Transceivers: | 6 Transceiver |
is the FPGA limits with limited transceivers ports? isn’t all FPGA IO port can be programed to do anything like ethernet or ....etc.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Based on the link given in my previous note, you can further branch out to search for the development kit that meet your budget.
For stock availablity kindly check with the Distributors in your region.
For Cyclone V dev kit, you can refer to below link.
https://www.intel.com/content/www/us/en/products/details/fpga/find-fpga-boards.html#sort=%40title%20ascending&f:facet2=[Cyclone%C2%AE%20V%20FPGAs%20and%20SoC%20FPGAs]&f:@psgcategoriesoffering_en=[Development%20Kits]
Regarding the Number of Transceivers, it depends on the Ethernet speed you want to achieve, i.e. 10M, 100M, 1G, 10G...
For a design that using triple-speed ethernet (10M/100M/1G), user can choose to use either the on-chip transceiver channels or LVDS I/Os.
However if the ethernet speed is 10G or above, need to use the high speed dedicated transceiver channels.
Triple-Speed Ethernet User Guide for your reference:
https://www.intel.com/content/www/us/en/docs/programmable/683402/21-3-19-5-0/about-this-ip.html
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- 2 RJ-45 connector (100Base-TX)
and
- 2 fibre optic LC connector (100Base-FX).
"My project does not need gigabit ethernet"
For that what should be the best solution to do that?
Also how can I also implement the following protocol into the FPGA ;
DNP3 , GOOSE and MODBU.?
Iam looking forward for your reply.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Q1) I actually want to use the FPGA to implement
- 2 RJ-45 connector (100Base-TX) and
Reply: It doesn't appear that any of our development kits have 2 RJ-45 connector + 2 fibre optic LC connector.
Q2) How can I also implement the following protocol into the FPGA;
DNP3, GOOSE and MODBU?
Reply: Modbus is an application layer protocol using RS-232 & RS-485, DNP3 consists of Application and Data Link Layers. It is a very old protocol (>40 years). We do not have these kind of example design in FPGA.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
What is the way to do that ?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Q3) According to the number of Input and outputs ports of the FPGA chip we have, can we add (implement) any number of ethernet (100base) RJ45 and fibre LC connector to the FPGA?
Reply: In the case of triple-speed-ethernet IP core, maximum ethernet port is 24.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
