21615 Discussions
Agilex 3 GTS PCIe IP missing
GabrielC
I plan a new design using PCIe 3 and LPDDR4 using Agilex3.
I already have a prototype project using an existing Cyclone 5 board, and it worked just fine.
I tried to move to Agilex3 (Quartus Prime Pro 25.1.1), but the IP is completely different.
My logic was designed with Avalon MM components, and for Cyclone 5 the IP was handling all TLP bridging to MM, and even had a tx channel for bus mastering (I used msgdma).
But I could not find anything similar for Agilex 3...
There is a PIO design example; even if it works, I also need tx bus mastering.
Do I have to handle all TLP myself?? I don't have the experience for this, might not be realistic...
Disabling the device compatibility, I see a lot for potential IP... e.g. GTS AXI Multichannel DMA, why is it just for Agilex 5?
I see online SSGDMA IP DMA PCIe... also only for Agilex 5??
Why this limitation?
Gabrile
Wincent_Altera
Based on my understanding, mSGDMA (Avalon-MM master) issues memory read/write requests. PCIe Hard IP receives these Avalon-MM transactions. PCIe Hard IP converts them into PCIe TLPs, sends them over the PCIe link. For incoming PCIe TLPs (targeting your FPGA), the PCIe Hard IP converts TLPs into Avalon-MM writes/reads, which mSGDMA can access. In common way, mSGDMA does not build or parse TLPs directly. Instead, it moves data to/from the PCIe Hard IP’s Avalon-MM or Avalon-ST interface. The PCIe Hard IP is responsible for converting Avalon-MM transactions into TLPs (and vice versa). I not sure if your previous implementation sound different or not.
>> detail how the PCIe HIP handle the TLP , you may refer to the user guide under https://www.intel.com/content/www/us/en/docs/programmable/813754/25-1-1/introduction.html
>> At the moment we just enable the ssgdma for Agilex 5,
>> For Agilex 3 we will use MCDMA as instead , the Estimation Delivery Data will be around next year , please stay tune.
>> there is build in PCIe PIO example design in Quartus under IP catalog
>> also , PCIe GSRD on https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/a3y135b.html
>> For tx bus mastering, we suggest to use MCDMA (to be release in future)
Hope that clarified
Wincent_Altera
GabrielC
I need both PIO (simple register access) and DMA (device to host only), the IP for Cyclone V handled this very nicely.
Yes, mSGDMA only handles MM transactions, the rest was done by IP. I mentioned this just for clarity, I expected to find similar functionality for Agilex 3 IP.
I don't think we can afford to wait until next year...
Thanks for your reply,
Gabriel
Wincent_Altera
Hi Gabriel,
SSGDMA only available for Agilex 5 , at current viewable roadmap I dont see there is any plan to implement it to Agilex3.
Most similar function based on your requirement will be MCDMA IP.
If you have strong business justification, I will suggest to talk directly to your any Altera Sales Rep/Distributor.
Hoping that this will fasten the development progress.
Let me know if there is anything else I can help
Wincent
GabrielC
Hello again,
I tried to play with the MCDMA IP, I just generated the example design.
I used "A5EC065BB32AE4S", a small device which matches most closely to what we planned.
But the compilation fails due to insufficient M20Ks!
(Error(170019): Project requires 489 M20K RAM blocks, but the selected device can contain only 229 M20K RAM blocks)
It needs almost 5MBit, almost all memory, but the fitter needs much more blocks.
I don't see any memory requirement settings... do you have any hint?? To tweak the buffers/fifos used inside the IP?
I understand that it could cost the performance, but that's acceptable.
For example, I don't need H2D at all... I would keep it at minimum.
Gabriel
Wincent_Altera
Hi @GabrielC ,
Based on the error code #170019, I found an information in link below:
In the error message stated that the design memory utilization is too large for the selected device. Hence, you would need to reduce the design. Tips to perform memory optimization
Wincent
GabrielC
Hi Wincent,
You missed the most important part
"the example design", I mean ONLY the example design (PCIe x1), no user logic, only generated boilerplate (gts pcie, gts mcdma, system PLL, reset, and 2 small demo onchipmem).
The MCDMA IP uses internally a LOT of memory! (e.g. mcdma used memory factor ~70x compared to pcie)
It just doesn't fit (memory, not logic) into smaller devices like A5EC065BB32AE4S
There are many/big buffers inside the IP (submodules), which need to be adjusted to fit.
See the attached report, "dma" is the MCCDMA and "dut" is the AXI PCIE IP.
The IP needs tuning parameters.
e.g. I don't need H2D and even reordering.
Gabriel
GabrielC
Hi Wincent,
I don't need SSGDMA explicitly.
I looked through MCDMA IP, and it looks like it offers all I need...
The problem is... the HW is in advanced design stage (I am mostly responsible for firmware) around Agilex 3, it matches the most (we don't need HPS for this project).
Additionally, I see Agilex 3 is already available, but Agilex 5 not.
Otherwise we have a real problem... going back to Cyclone V would be the worst case solution...
If I understand correctly, MCDMA is only "soft" IP. I would be optimistic to get it for A3...
Would it be possible to get some kind of "early beta" access? To be able to progress with my firmware design?
Gabriel
Wincent_Altera
Hi @GabrielC ,
>> I understand your concern, That why I would suggest you to reach out to any of your cognizant Altera FAE/DFAE to check if the beta version is available or not
>> or you may try to submit your enquiry via https://www.altera.com/contact
Let me know if you have any further question.
Wincent
Wincent_Altera
Hi @GabrielC ,
Is there anything else you think I can better assist you via this thread ?
Wincent
GabrielC
Hi Wincent,
As I wrote here ( community.intel.com/t5/Programmable-Devices/Agilex-3-GTS-PCIe-IP-missing/m-p/1716620#M101270 ), the focus changed to implementing/using on smaller devices (Agilex 5 is similar in price for the similar size, but no availability yet).
Should I open a new/dedicated thread?
Gabriel
Wincent_Altera
Hi Gabriel,
Please accept my sincerely apology that I cannot help too much on this issue.
As mentioned the MCDMA for Agilex 3 ETA (subject to change) will only be available next year onwards.
If you really have a strict price concern, or device selection issue, I would strongly suggest you to reach you to any of your local Distributor Field Application Engineer (DFAE). I believe they can help to address your concern on both device and price selection.
Let me know if there is anything about the PCIe that I can better assist. I would happy to help out.
Wincent
GabrielC
Hi Wincent,
You missed an important detail again...
I wrote explicitly, it fails for Agilex 5 (A5EC065BB32AE4S)!!
I chose a similar sized device; the price is also comparable, it could be a good option if it would also be available.
But MMap (PIO) and DMA (D2H) is a must, and I need a solution...
Gabriel
GabrielC
Sorry, I meant A5EC008BB32AI6S
But I get from one problem to the other...
I was looking for SSGDMA, and it's not visible at all, for Agilex 5 (the same device)
What am I doing wrong?? (Quartus 25.1.1)
Gabriel
jc_ddc
SSGDMA seems to have disappeared in Quartus 25.1.1 on both Windows and Linux versions of Quartus for me as well (using the Agilex 5). I was able to create the IP in 25.1 and then migrate the project to 25.1.1.
Wincent_Altera
Hi @GabrielC
If you are targeted Agilex 5 instead of Agilex 3, then you can move back to SSGDMA solution.
Thanks community contributor @jc_ddc for helping to answer that.
Gabriel , can you please try to generate the SSGDMA IP via 25.1 , then migrate it into 25.1.1 (if that is compulsory for you ?)
The SSGDMA is in progress of ip enhancement, that why it is missing in the newest release.
GabrielC
I installed back 25.1 and I was able to create SSGDMA instance.
But I was curious about changes and made a diff between 25.1 and 25.1.1
Among some technical changes, "intel_ssgdma_hw.tcl" (25.1.1) contains:
- set_module_property SUPPORTED_DEVICE_FAMILIES {"Agilex 5" "Agilex 3"}
this sounds nice :), but how about this ???
-  # ssGDMA Deprecation Warning
-  send_message warning "The sSGDMA IP is not recommended for new projects and is subject to removal in a future release. mSGDMA IP is the recommended replacement for SoC mode. GTS AXI MCDMA IP is the recommended replacement for PCIe mode."
I am confused again...
Gabriel
Wincent_Altera
Hi @GabrielC ,
In future, We wont support sSGDMA, and totally disappear in Quartus IP catalog
BUT for long term development, I would suggest to check on MSGDMA / MCDMA for Agilex 5.
Reason is due to MSGDMA is more modular, configurable, efficient, and better supported for current and future FPGA designs. This change ensures better performance, easier integration, and ongoing support, making it a clear upgrade for most applications.
Wincent_Altera
GabrielC
I have the feeling that you miss the whole picture... so let me summarize.
We try to migrate to a new chip generation (Agilex 5/3 with PCIE) and you tell me/us:
- no support in the future for SSGDMA (not "future", even current version 25.1.1 has no support; curiously, the IP got some technical tweaks together with the deprecation note )
- no support for MCDMA for smaller devices (resource tweaks not possible)
- mSGDMA has no PCIE TLP support, not relevant (as the deprecation notes, it's only for SOC/MM)
Forget the "DMA" name, I just need PCIE TLP IP. The old CycloneV IP worked just fine with my design (I used indeed mSGDMA to feed into the tx interface, but I can use my own logic).
What option do I have (or what do you recommend) with PCIE TLP support and smaller devices?? Why are these devices available with PCIE but no IP support?
Gabriel
Wincent_Altera
Hi @GabrielC ,
I understand how your feeling, but I am trying my best to assist you in either way.
Please accept sincere apologies if there is any inconvenience cause to you.
>> This information is available under the user guide 1. Product Discontinuance Notification
>> Passing the message with reason to ensure that you choosing the the best implementation for your future project
>> You can try to select a lower number of DMA channels
>> lower the data width for example 32 , 64 bit
>> control the amount of data transferred per dma burst
>> configure the "max burst size" to match your system's output correctly
>> those can be configure via the IP catalog.
>> I will pass this escalation back to our internal team.
>> If you really have a strict price concern, or device/ip selection issue, I would strongly suggest you to reach you to any of your local Distributor Field Application Engineer (DFAE). I believe they can help to address your concern.
Again, please accept my sincerely apologies for any inconvenience causing to you (if have).
I will raise up your concern to our development team, as user feedback always a top priority that we would take it seriously.
Let me know if there is anything else I can assist you more.
Wincent_Altera
Wincent_Altera
Hi Gabriel,
Is there anything else you think I can better assist you ?
Wincent
