21607 Discussions
Agilex 5 FPGA Optical Module Support
SDavi9
For the Agilex 5 FPGA E-Series - what Optical module support does it have ? In the device overview I found a note "SFP+ only available on D-series" but on the other hand from "Transceiver-based protocols supported on the Intel Agilex 5 FPGAs are shown in Table 3." it would appear that there is optical support for numerous different protocols ?
Also where can I find the data sheet for this FPGA ?
Kshitij_Intel
Your understanding seems to be correct that is SFP+ optical module support for different protocols. Still, I will check once internally and let you know.
Thank you,
Kshitij Goel
Kshitij_Intel
Do you have any further question?
Thank you,
Kshitij Goel
SDavi9
Dear K**bleep**ij,
What did you find out from your internal check ? Please be specific and indicate which versions of Agilex 5 FPGA have SFP+ optical module support ?
Best regards
Shmuel
SDavi9
Any News ? We really need the documentation on the full extent of the optical support for Agilex 5 E-Series Device Group B M16A, B15A & B18A FBGA's
Kshitij_Intel
Allow me some time, I am checking on this.
Kshitij Goel
SDavi9
Thank you so very much !
Please me me know when you have something !
SDavi9
If the Agilex 5 E-Series Device Group B  does support an optical interface - is there a chance of getting hold of a design e.g. (as far as I understand the design e.g. are for Agilex 7 ???) ??
Kshitij_Intel
As we know, SFP+ is supported on Agilex-5. SFP is not as it violates the input voltage of the GTS Rx.
Thank you,
Kshitij Goel
SDavi9
Dear K**bleep**ij,
Thank you for getting back to me.
Is SFP+ supported on Agilex 5 E-Series Device Group B M16A, B15A & B18A FBGA's ? Do you have nay documentation on this ? Do you have a Quartus design e.g. for this ?
Bests regards
Shmuel
SDavi9
Any update ?
I just re-checked the Agilex 5 Device overview and I could not find the note "SFP+ only available on D-series" - was there an update to the Documentation ?
Kshitij_Intel
I have asked to the engineering, please wait for some time on the specific info for D-Series.
Thank you,
Kshitij Goel
SDavi9
Kshitij_Intel
As long as the SFP+ module electrical signal spec meets Agilex 5 transceiver spec then no issue interface with Agilex 5.
SDavi9
Does this also apply to Agilex 5 E-Series Device Group B M16A, B15A & B18A FBGA's ?
Why was there an original note that stated "SFP+ only available on D-series" ?
Please could you direct me to a Quartus design that could be used with the Agilex 5 E-Series Device Group B that could also be implemented on the Agilex 5 development boards
Kshitij_Intel
As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Kshitij Goel
