21600 Discussions
Agilex 5 transceiver output clock
Asaf_Bloch
Hello Intel team,
We use the transceiver output clock, it CML format.
The CML output consists of a differential pair with
50Ω collector resistors, as shown in Figure 3
Is the Agilex-5 implement this 50Ω collector resistors and what is the VCC voltage?
When interfacing with differential CML receiver, do we need external components other than AC couple capacitors?
Asaf
WZ2
Hi Asaf,
Thank you for your question.
Yes, the Agilex™ 5 transceiver CML output includes internal 50Ω collector resistors, so no additional external termination resistors are needed. When interfacing with a differential CML receiver, you only need to add AC coupling capacitors.
For recommended connection guidelines and further details, please refer to Intel's official Pin Connection Guidelines (PCG):
https://www.intel.com/content/www/us/en/docs/programmable/813266/current/pin-connection-guidelines-fpgas-and-socs.html
WZ
