I would like to calculate the following metrics for the Agilex 7 series:
-Peak FP32/FP16 FMA TFlops
-Peak FP32/FP16 TFlops
-Peak FP32/FP16 TFlops / mm^2 of fabric
How would I calculate these?
I am also looking for the Local Memory Bandwidth, Memory Bandwidth, and die area of the part.
Can someone assist me?
Thank you for your time!
Seem like a gpu problem. Could you post here https://community.intel.com/t5/Graphics/bd-p/graphics to get help?
Sheng
Please ignore previous post.
Peak FP32/FP16 FMA TFlops:
Peak FMA TFlops = (Number of FP Units × Clock Frequency in GHz × 2)GFlops / 10^12
Peak FP32/FP16 TFlops:
Peak TFlops = (Number of FP Units × Clock Frequency in GHz)GFlops / 10^12
Peak FP32/FP16 TFlops / mm^2 of fabric:
TFlops/mm² = Peak TFlops / Die Area in mm²
Shows example for AGF027:
can get total DSP is 8528, FP32/FP16 fmax is 750mhz/0.75ghz (refer here https://www.intel.com/content/www/us/en/docs/programmable/683301/current/dsp-block-specifications.html )
FP32 Peak FMA TFlops = (8528*0.75Ghz*2)GFlops/10^12 = 12.8TFlops
FP16 Peak FMA TFlops = 12.8*2 = 25.6TFlops
I'll research and post later the rest formula.
Sheng
Thank you for your help! I will wait for the rest.
Are peak TFLOPs the same for FP32 and FP16 ? These equations seem to suggest that.
Disregard, I see that the equations are different. I mis-read.
Hi David,
For your question about local memory bandwidth, memory bandwidth and die area of the part, are you looking for M20K, MLAB or EMIF? Or another memory?
Adzim
For die area, I'm asking for die area of the FPGA itself.
For my memory question, I would like the maximum bandwidth for the EMIF as well as M20K and MLAB. I understand that these numbers are dependent on multiple factors, but I'm looking for a highest performance type of metric.
For DDR4 memory, i have this equation:
DDR4 Memory Bandwidth = (Data Rate (MT/s) * Bus Width (bits) * #channels ) /8
Based on the F-Series product table I calculated the DDR4 memory bandwidth as follows:
DDR4 Memory Bandwidth = (3.2) * 64 * 4) / 8 = 102.4 GB/s
Does this make sense?
For the M20K and MLAB, I don't know what formula would be use to calculate bandwidth.
Hi David,
For the die area, I think you can refer to FPGA package. For example:
Your calculation on DDR4 bandwidth should be okay.
For the embedded memory, you may refer to the link below:
- https://www.intel.com/content/www/us/en/docs/programmable/683241/25-1/embedded-memory-features.html
- https://www.intel.com/content/www/us/en/docs/programmable/683458/current/key-features-and-innovations-in-fpgas.html
Adzim
Hi David,
Did my previous reply have answered your questions?
Or you still got questions regarding that?
Adzim
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
