Agilex5のVREFP_ADCについて高精度なADCの精度を求める場合は1.25Vの電圧を入力するとのことですが、この端子に流れる電流はどれくらいになりますでしょうか?
精度が高い1.25Vを供給できる部品でコスト面でよいものがないので、他の電圧からの抵抗分割(数kΩ)で供給できればと考えていますが、流れる電流によっては使えない方法かと思っています。
To achieve high-precision ADC performance on Agilex 5, Intel recommends supplying 1.25V reference voltage to VREFP_ADC pin. However, the current drawn by this pin is not explicitly stated in the datasheet.
Typically, FPGA ADC reference inputs like VREFP_ADC are designed as high-impedance inputs, meaning they draw very little current- usually in the range of microamperes(uA). This allows external precision voltage sources to drive the pin without significant loading.
Regarding using resistor divider for 1.25V, only suitable for below conditions :
1- VREFP_ADC has high input impedance
2- output impedance of the divider is low enough to maintain voltage stability.
3- your design includes an op-amp to prevent voltage sag due to load changes or noise.
You may want consider below alternatives:
1- Low-cost precision voltage reference ICs eg. TI REF3312, or Analog Device ADR125 etc.
2- Resistor divider + Op-amp buffer implementation.
regards,
Farabi
