Programmable Devices
20778 Discussions
Altera Modelsim
I have a very simple design in Quartus Web Pack ver 11.0 , and with it i have Modelsim-Altera Starter ver 6.6d. I get these error messages "vsim-19" when i do rtl-level simulation .
"failed to access library tb_xxx st tb_xxx"
I used the same vhdl files and run the simulation in Modelsim ver 6.2 SE and i see results as expected ???
I have checked the mapping of lib using vmap it is ok .
What is the problem ???
</SPAN>
From your picture, there is no tb_ezusb library.
This is how i have set up the test bench .
i have a simple counter design with the same tb setup and its RTL simulation works.
