Programmable Devices
21602 Discussions
Altera PLL 12.0 or 12.1 with Cyclone V
Hi, my name is Jean and I use Cyclone V for my design.
I use a Altera PLL (version 12.1) to have a 100MHz clock from 10MHz base clock (Reference Clock).
My reference clock is a gclock and when I simulate this PLL (with ModelSim), no output work (No Lock and no output clock)!!
I have made a reset (low, high and low) and I have any result !!!!!
I have made the same thing with Cyclone IV and altpll and it work fine.
Do you have any Idea ?
It's Altera ModelSim or me :) ?
Thank you
The operation mode is Normal or direct, PLL Mode is Integer-N PLL.
One output Clock at 100MHz
Reference clock at 10MHz
The result is (from ModelSIm, outclk_0 = the output of PLL):
** Warning: (vsim-8684) No drivers exist on out port /tb_testalgo/b2v_inst/outclk_0, and its initial value is not used.
** Warning: (vsim-8684) No drivers exist on out port /tb_testalgo/b2v_inst/locked, and its initial value is not used.
Jean
also, When I compile my test design, I have a warning:
Warning (332056): PLL cross checking found inconsistent PLL clock settings:
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[1] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[2] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[3] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[4] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[5] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[6] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Warning (332056): Node: inst|testpll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[7] was found missing 1 generated clock that corresponds to a base clock with a period of: 100.000
Other warning when I compile:
10034 Output port "phout" at altera_pll.v (275) has no driver
10034 Output port "cascade_out" at altera_pll.v (275) has no driver
