21611 Discussions
Altera opencl, Diff usage of Processors when using parallel compilation of Quartus.
I am using "Hello world" of example designs offered by Altera Opencl. (https://www.altera.com/products/design-software/embedded-software-developers/opencl/developer-zone.html#design-examples
I use the "aoc" command and get the .aocx file.
but I have a confusion:
in the file "top.sta.rpt", it have something like this:
  • ; Parallel Compilation ;
  • ; Processors ; Number ;
  • ; Number detected on machine ; 8 ;
  • ; Maximum allowed ; 4 ;
  • ; Average used ; 1.08 ;
  • ; Maximum used ; 4 ;
  • ; Usage by Processor ; % Time Used ;
  • ; Processor 1 ; 100.0% ;
  • ; Processors 2-3 ; 2.9% ;
  • ; Processor 4 ; 2.2% ;
Problem:
1. Why Processor 1 is using 100%, and other Processor only use nearly 3% ?
2. How can I increase the usage of Processor 2-4 ?
Thank you, wait for your apply~
Is there anyone face this problem?
Hi pengbo,
I am having a similar problem. In my case the base.sta.rpt is as follows:
; Number detected on machine ; 24 ;
; Average used ; 1.57 ;
; Processors 2-4 ; 19.0% ;
Also, my machine has 24 processors, but I am only able to use 4 processor.
I tried changing the settings in Quartus Prime Pro 15.2, Assignments > settings > Compilation Process Settings to "use all available processors", but the result is the same, I cannot use more than 4 processors.
I still don't solve this.
You can try to changing the settings : Assignments > settings > Compilation Process Settings "Maximum processors allowed 8".
If you have only progress, please contact me in the forum or my e-mail: buaapengbo@126.com
thank you for your apply!
