Apply to do FA
weichen
This IC's MPN is 10M04SAU169C8G, DC: 2013 , Flex PN: : KSIH- 53550-2003-000.
Cause : Function test fail. input qty:756 pcs, Defect qty:24pcs, fail rate: 3.1%
 reference tested data:
#1,D/C:2013,F5 to A1 resistance value is less than 10Ω, normal more than 30KΩ.
#2,D/C:2013,F5 to A1 resistance value is less than 10Ω, normal more than 30KΩ.
#3,D/C:2025,F5 to A1 resistance value is less than 10Ω, normal more than 30KΩ.
#4,D/C:2025,F5 to A1 resistance value is less than 10Ω, normal more than 30KΩ.
#5,D/C:2025,F1 to A1 resistance value is less than 10Ω, normal more than 30KΩ.
Zawani_M_Intel
Hi ,
I need to know some further info to this failure issue.
I will send you an email. Please do let me know if you do not receive.
Wani
weichen
When will I receive your reply?
Zawani_M_Intel
I sent a message to you previously. Can I know if you can view it? Else, I will resend.
Wani
