Programmable Devices
21615 Discussions
Aproblem about processor reset
I have a sopc system which has two CPU(CPU0 AND CPU1).And there is a watchdog connect to the cpu0 ,when the timeout pulse is generated by the watchdog ,both of the two CPU is reset.I want to know that what can do if I want to only reset CPU0 once the timeout pulse is generated.
THANKS!
you may create per cpu reset quest,
sopc builder-> cpu0 -> advanced feature, select generate cpu_resetrequest
- Hippo
Many thank for your answer !!
