21594 Discussions
Are there any TFT LCD libraries or IP available?
I'm new to fpgas and I'm at the point where I want a (little) bigger project. I would like to connect a display to my BeMicro MAX10 board but I don't want to use a character based LCD. I've used those with PIC18... before. I was wondering if there is any (free or not too expensive) TFT LCD ip since the only display ip I can see in the quartus ii is for a 16x2 character base display. I'll appreciate any comments you may have.
--- Quote Start ---
--- Quote End ---
Have a look at following. It may be useful.
http://www.slscorp.com/ip-cores/display/vgalcd-controller.html
Cheers,
Bhaumik
Consider using a SPI based display. No need for a special FPGA core then. There are plenty on eBay and Amazon. You would probably need a SPI voltage level shifter like https://www.sparkfun.com/products/12009.
