21607 Discussions
Arria 10 IBIS AMI model selector for supporting VOD setting 12.
Vincent222
I had arria 10 IBIS_AMI model and try to simulate transceiver output with "A10_V12_R100_SLEW4" model selector option.
I am using HyperLynx.
By the excel file(arria-10-cyclone-10gx-pre-emphasis-and-output-swing-settings.xlsx) from Intel, I expect 330mVp-p output w/o no pre and post tap.
But I always have 1Vp-p at the transceiver output with HyperLynx tool.
please let me know how I could have consistent result between excel file and Arria10 IBIS-AMI with HyperLynx.
Vincent222
the eye diagram from hyperlynx is above and always have the same amplitude.
Kshitij_Intel
Can you please confirm, are you using the latest IBIS-AMI model mentioned in the link below.
https://www.intel.in/content/www/in/en/support/programmable/support-resources/board-layout/ibs-ibis-index.html
If yes, please share your IBIS-AMI Model folder and the spreadsheets you are using.
Thank you
Kshitij Goel
Vincent222
I am using version 2.0,  file name arria10_gxgt_hssi_ibis_ami_v2p0. my reference excel sheet is attached.
I am comparing the amplitude of excel file and IBIS_AMI model output.
Kshitij_Intel
Hi Vincent,
There is a possibility the VOD has not been set as 12 even though you are setting it. Please check once are you correctly setting the VOD, VCCT and data rate?
Thank you
Kshitij Goel
Kshitij_Intel
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
Vincent222
I set VCCT, VCC and data rate correctly and changed VOD by selecting corresponding model by model selector.
But I could not have any difference.
DO you have any sim result with this IBIS_AMI model in any simulator to clarify the VOD amplitude?
eye diagram with A10_V31_R100_SLEW_5 are below..
eye diagram with A10_V12_R100_SLEW_5 are below..
Vincent222
Hello K**bleep**ij,
DO you have any feedback?
