21600 Discussions
Arria 10 SoC 10AS016 IO level
SB_S
This series doesn't support 3.3V of IO . Instead of 3.3V , it supports 3V .
Can we still connect the 3.3V signal to FPGA and does it capable of driving 3.3V ?​
SreekumarR_G_Intel
I believe you are talking about VCCIO supply , if so .. , it is not recommended to use the 3.3V on this rails as per datasheet. you can connect these pins to 1.2V, 1.25V, 1.35V, 1.5V, 1.8V, 2.5V, or 3.0V supplies, depending on the I/O standard required by the specified bank..
Refer below link for more details (Supply pin section - Design guidelines from Intel.
https://www.intel.com/content/www/us/en/programmable/documentation/wtw1404286459773.html#wtw1420544425270
Thank you ,
Sree
SB_S
​IF we have the device which supports only 3.3V , can we still connect these device IO to FPGA with VCCIO 3.0 V ? Is it is 3.3V tolerant ?
SreekumarR_G_Intel
As per intel Arria 10 Datasheet recommendation it should be 3.15V (max). The IO Voltage is beyond the max value mentioned in the datasheet, Intel will not guarantee the proper working for the IO functions.
Thank you ,
Sree
