Dear Sir,
I am working on a design on the DE5A-NET-DDR4. But it is not for 10G or 40G Ethernet. It is a Gigabit Ethernet design. It is from our old project. It was working well on the Arria 5 starter kit. It uses a TSE with LVDS design for the PCS and PMA. I am not modify it onto the DE5 board, by modifying the PMA into GXB. In addition, the GXB needs two additional clocks, tx_serial_clk and rx_cdr_refclk. I have used an fPLL to generate a mcgb_serial_clk for the tx_serial_clk and a 125Mhz from input pin (it is from a clock synthesizer si5340). The compilation is ok now. The PCS configuration is follow the TSE manual to set as below. 0x13 = 0x13 0x12 = 0x12d0 0x00 = 0x5140 0x14 = 0x0000 0x00 = 0xd140 The attached jpg file is the verilog code for the tse connection check. I don't know why the pcs loopback is not working. Regards, Peter Chang https://www.alteraforum.com/forum/ce3c51c9-3a1a-4ff7-be7e-d79a07705ee4Link Copied
Topic Options
