21584 Discussions
Arria 10 spine clock region overused
I'm trying to build a fimware with several transceiver banks. If I use 4 banks, it's fine. But 5 banks cause congestion in the "spine clock region" and the compilation sits in "IO Placement" for about an hour and eventually gives up with the follow error (my guess at the relevant part is highlighted in red). I've not see this error before. Any thoughts would be appreciated.
Error (14996): The Fitter failed to find a legal placement for all periphery components
Info (14987): The following components had the most difficulty being legally placed:
Info (175029): Clock core fanout containing node LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:1:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|gwt_tx_top:gwt_tx_4|tx_fifo:tx_fifo_inst|dcfifo_mixed_widths:dcfifo_mixed_widths_component|dcfifo_k1t1:auto_generated|altsyncram_5k91:fifo_ram|ram_block9a0 and 31 other node(s) driven by auto-promoted clock driver
Info (175029): Clock core fanout containing node LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:3:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|gwt_rx_top:gwt_rx_5|pile_and_shift:PILE|data_scrambler_input[106] and 948 other node(s) driven by auto-promoted clock driver LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:3:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|GWT_6ch_altera_xcvr_native_a10_161_pn5wopi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[5].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5:twentynm_xcvr_native_inst|twentynm_pcs_rev_20nm5:inst_twentynm_pcs|w_hssi_rx_pld_pcs_interface_pld_pcs_rx_clk_out~CLKENA0 and auto-promoted clock driver LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:3:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|altera_reset_controller:rst_controller|altera_reset_synchronizer:alt_rst_sync_uq1|altera_reset_synchronizer_int_chain_out~CLKENA0 (9%)
Info (175029): auto-promoted clock driver LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:4:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|GWT_6ch_altera_xcvr_native_a10_161_pn5wopi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[1].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5:twentynm_xcvr_native_inst|twentynm_pcs_rev_20nm5:inst_twentynm_pcs|w_hssi_rx_pld_pcs_interface_pld_pcs_rx_clk_out~CLKENA0 (6%)
Info (175029): auto-promoted clock driver LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:4:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|GWT_6ch_altera_xcvr_native_a10_161_pn5wopi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[4].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5:twentynm_xcvr_native_inst|twentynm_pcs_rev_20nm5:inst_twentynm_pcs|w_hssi_tx_pld_pcs_interface_pld_pcs_tx_clk_out~CLKENA0 (5%)
Error (14986): After placing as many components as possible, the following errors remain:
Error (13081): The Fitter cannot route to 1 clock core fanout
Info (14596): Information about the failing component(s):
Info (13207): The clock core fanout consists of 40 node(s)
Info (13205): Sample node name: LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:4:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|gwt_tx_top:gwt_tx_0|coe_GWT_TX[0]
Info (13208): This core logic is driven by 1 clock source(s)
Info (14900): auto-promoted clock driver LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:4:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|GWT_6ch_altera_xcvr_native_a10_161_pn5wopi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5:twentynm_xcvr_native_inst|twentynm_pcs_rev_20nm5:inst_twentynm_pcs|w_hssi_tx_pld_pcs_interface_pld_pcs_tx_clk_out~CLKENA0
Info (14894): This signal is currently using global clock 13, with the buffer placed at CLKCTRL_1C_G_I13
Info (175013): The auto-promoted clock driver is constrained to the region (0, 5) to (224, 213) due to related logic
Info (175015): The I/O pad rx_gbt[24] is constrained to the location PIN_R3 due to: User Location Constraints (PIN_R3)
Info (14709): The constrained I/O pad is contained within a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_TX_PLD_PCS_INTERFACE, which drives this auto-promoted clock driver
Info (175015): The I/O pad rx_gbt[25] is constrained to the location PIN_P5 due to: User Location Constraints (PIN_P5)
Info (14709): The constrained I/O pad is contained within a HSSI_RX_CHANNEL_CLUSTER, which is contained within a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_10G_TX_PCS, which drives a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_TX_PLD_PCS_INTERFACE, which drives this auto-promoted clock driver
Info (175015): The I/O pad rx_gbt[26] is constrained to the location PIN_N3 due to: User Location Constraints (PIN_N3)
Info (14709): The constrained I/O pad is contained within a HSSI_RX_CHANNEL_CLUSTER, which is contained within a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_8G_RX_PCS, which drives a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_10G_TX_PCS, which drives a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_TX_PLD_PCS_INTERFACE, which drives this auto-promoted clock driver
Info (175015): The I/O pad rx_gbt[27] is constrained to the location PIN_M5 due to: User Location Constraints (PIN_M5)
Info (14709): The constrained I/O pad is contained within a HSSI_RX_CHANNEL_CLUSTER, which is contained within a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_8G_RX_PCS, which drives a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_8G_RX_PCS, which drives a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_10G_TX_PCS, which drives a HSSI_DUPLEX_CHANNEL_CLUSTER, which contains a HSSI_AVMM_IF, which drives a HSSI_TX_PLD_PCS_INTERFACE, which drives this auto-promoted clock driver
Error (16234): No legal location could be found out of 30 considered location(s). Reasons why each location could not be used are summarized below:
Error (177032): Section clock (SCLK) network in spine clock region bounded by (111,87) and (159,113) is overused
Info (18630): This congestion may be avoided by moving or disabling promotion of any of the following competing signals:
Info (175030): Unroutable signal:
Info (175026): Source: auto-promoted clock driver LLI:lli_inst|GWT_6ch:\multiLink_gen_loop:4:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|GWT_6ch_altera_xcvr_native_a10_161_pn5wopi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5:twentynm_xcvr_native_inst|twentynm_pcs_rev_20nm5:inst_twentynm_pcs|w_hssi_tx_pld_pcs_interface_pld_pcs_tx_clk_out~CLKENA0
I managed to fix this by setting the clocks to non-global clock. Here's the constraint that did the trick. There must be one constraint like this per channel.
set_instance_assignment -name GLOBAL_SIGNAL OFF -to "LLI:lli_inst|GWT_6ch:\\multiLink_gen_loop:1:multiLink_gen_gwt:u0|GWT_6ch_GWT_BANK_10_up7bqka:gwt_bank_0|GWT_6ch_altera_xcvr_native_a10_161_pn5wopi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5:twentynm_xcvr_native_inst|twentynm_pcs_rev_20nm5:inst_twentynm_pcs|out_pld_pcs_rx_clk_out"
Karol.
