21615 Discussions
Arria V SoC Development Board
I am trying to work with Arria V SoC Development Board.
When trying to use the BoardTestSystem tool that is in the software kit for the board, I get "No JTAG cable is detected or selected".
But, I am able to see the JTAG chain (when doing autodetect) from the Quartus Prime Programmer interface.
Are there settings I need to change for the BoardTestSystem to see the Arria V SOC development board?
Hi, if I am not mistaken, the Board Test Tool require you to have the same Quartus version as the version from which it was built/generated. If you download the files from this link:
https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arriav/arriavst_5astfd5kf40_soc_v15.1.0b185.zip
Then I believe you have to use Quartus 15.1 in order to get the board test system program works.
You also need to ensure the environment variable is set correctly.
See this KDB for detail information:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10312012_472.html
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03142012_866.html
(This message was posted on behalf of Intel Corporation)
