Assignment pin
Hey
I want to do the assignment pin to StratixII and I want to know what is the fastest and the best way to do it?
I know that there is a way to write VHDL file with attributes, is someone know what is the format to write? and if there is format for Verilog file?
Shishko
you can do this in the rtl directly using chip_pin.
search for chip_pin in quartus help.
here is the example from the help
// Traditional comment-style syntax
module foo(sel, data, o);
input sel /* synthesis chip_pin = "C4" */;
input [3:0] data; /* synthesis chip_pin = "D1, D2, D3, D4" */;
output o;
// Specify module body
endmodule
// Verilog-2001 attribute syntax
(* chip_pin = "C4" *) input sel;
(* chip_pin = "D1, D2, D3, D4" *) input [3:0] data;
output o;
endmodule
--dalon
