Attribute Altera
Which is the equivalent command to map in a lut an architecture for alterA?
In Xilinx project i use the attribute xc_map: string;
attribute xc_map of rtl : architecture is "fmap";
In the Altera project, is it possible?
So all the architecture in my project will be placed in different lut and i can use the placemente in the tcl script with the command
set_location_assignment.
Thank you
