21600 Discussions
Autogenerated altshift taps
https://alteraforum.com/forum/attachment.php?attachmentid=15412&stc=1
Dear Developers,
I am creating a code where I used memory , however there is a part of memory that I didn't actually use , it is "auto generated" called altshift taps as shown in image, Kindly I need a justification for adding it by Quartus.
Many thanks.
FPGA synthesis never implements any resource that isn't "actually used". I guess the problem is that you don't understand which part of the code infers a RAM based shift register. But without seeing the code, it's hard to tell.
The hierarchy view already tells you that it's used in the implementation of dataodd_rtl. There's no additional autogenerated logic, it's just the way how altshift_taps is implemented.
--- Quote Start ---
--- Quote End ---
I used data odd here :
BEGIN
IF (rising_edge (clk)) THEN
Splitter<=Original(generaladdress);
dataeven <= Splitter(9 downto 0);
dataodd<=Splitter(19 downto 10);
if kk=2 then
First_Reg<=dataeven;
else
evenbuff<= dataeven;
end if;
xoddbuff<=dataodd;
oddbuff<=xoddbuff;
It temporary holding a value since I need to wait for one clock cycle, however, I defined it as signal of unsigned, I don't know why it used as m4k?
The shown code snippet doesn't give reason to expect altshift_taps inference. I guess, i's not the full picture.
There is nothing surprising here as by default the tool is made free to infer memory for some shift operations. The user can disable that in the project settings.
altshift_taps is used for multicycle shift registers. But there's no respective function in the shown code snippet.
--- Quote Start ---
--- Quote End ---
I tried to disable it here but it doesn't workhttps://www.alteraforum.com/forum/attachment.php?attachmentid=15420
Thanks for reply, the only place I used that signal (dataodd) is here! How can I disable it? Regards.
I don't see you have chosen the right setting.
I believe it should be something like: Auto Shift Register Recognition OFF.
You can also apply it specifically to your signal using attribute.
I didn't notice such settings .. :(
