21610 Discussions
Avalon MM preformance
I just started to play with NIOS2 and its parts, and after I could get my_first_niosII.. to work, I was curious about how is the speed of pheriperials, for example the uC like PIO. This one is very slow, but I do assume that the vendor (Altera?) has put many wait states. So I created own new component as some kind of fast PIO. It was a bit faster, but not really fast. I was driving the NIOS/f on 125 Mhz, and I could get around one fourth / fifth of this speed on the bus. I've tried in burst mode too, but really could not reach better result.
Perhaps I'm too greenhorn yet to NIOS, so guys I would appreciate very much if some of you could explain me what kind of steps I need to do to get faster PIO like stuff. Target is not memory something, even not INT driven source, etc. Just simple high speed parallel data exchange.
Exchanging data through an Avalon MM interface is not the fastest way. The CPU looses a lot of cycles fetching the data and writing it back. If you need a fast parallel interface, you should rather use an Avalon Stream interface.
Have a look at the SGDMA component to read/write data from memory to an Avalon stream.
Thank You for the answer! Really I'm not much surprised, I was expecting some similar reply.
