21611 Discussions
Avalon interface data width vs. external memory data width
Dear all, can I ask a question?
We all know avalon interface are 32 bits, but most external memory are 8 bits or 16 bits,
Where the extra bits go when DDR/DDR2 SDRAM HP controller write to the external memory? Which one happens in the following case?
For a 32 bits local_wdata, the total 32 bits from HP controller are sent to the mem_dq bus 2 or 4 times, only the lower 16 bits/8 bits are selected by the memory? if so, how the memory know which one to select?
or only the lower16 bits/8 bits selected by HP conroller and sent to mem_dq bus?
Thank you very much!
