21602 Discussions
BSP editor - Custom search path
I'm using Quartus 10.0 and NIOS2EDS 10.0 and I can see that in the BSP editor it is no longer possible to set custom search path in Tools->Options..
The 10.0 software handbook sais that this is still the way to do it, but there is clearly no option for this in the BSP editor...
This was possible with version 9.1sp2 at least.
Does anyone know how i can set the custom search path in BSP editor 10.0????
Is there no one, that can help me?
Hi dcaradiocomp,
I have the same problem with Quartus 11.0 SP1... Did you solve your problem?
Thank you,
Paolo
OJezek
The path must be properly set in global quartus search paths. If the path is only in QSYS (System builder) then it does not work properly in bsp editor.
