21615 Discussions
Bidir pins together ?
I'm currently trying to connect two bidir pins together in a schematic with quartus (as you can see on the picture)
but, i don't why, i get this error : BIDIR pin "xxx" feeds BIDIR pin "yyy"
maybe i should put something between my two bidir ?
but which component because I only need (must have) a wire
Thanks in advance
you can't do that. without control logic, should a pin be input or output ?? in which directions should the sinal flow be from left to right or vice versa ?
you need to control that with an output enable
Each bidir pin must be driven by a tri-state driver.
