I am attempting to run the NIOS II program example 'binary count' but seem unable to download the elf file. The specific error is: "Downloading ELF Process failed." From the error window there is no more information other than that.
I am running on the Altera DE2 board, Cyclone II EP2C35F672C6N. My initial attempt to run it failed due to not enough memory on my SOPC. I added SDRAM running on a clock that is 3 ns slower than the clock used for the NIOS II processor. Which was done through a pll. Looking up this error I found that the most common root of this problem is a timing issue. I am not sure what the timing should be for this project. I chose 3 ns as the clock for SDRAM because that is what the tutorial I followed chose. If I limit the memory for the program by choosing code optimization and using small C library, and using onboard memory than I can get the LED and the HEX to light up. But when I introduce SDRAM memory than I run into the ELF file error. If I try to create a new BSP I run into the same issue. SOPC Content: -CPU - NIOS II -SDRAM -JTAG Interface -System ID -LCD Display -Button PIO - 4 bit input (toggle switches) -LED PIO - 8 bit output -Seven Seg PIO - 16 bit outputLIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY memTest IS
PORT(KEY: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
CLOCK_50: IN STD_LOGIC;
LEDG: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
SWITCHES: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
HEX: OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
-- 16 X 2 LCD Module
LCD_ON, -- Power ON/OFF
LCD_BLON, -- Back Light ON/OFF
LCD_RW, -- Read/Write Select, 0 = Write, 1 = Read
LCD_EN, -- Enable
LCD_RS : OUT STD_LOGIC; -- Command/Data Select, 0 = Command, 1 = Data
LCD_DATA : INOUT STD_LOGIC_VECTOR(7 downto 0); -- Data bus 8 bits
-- SDRAM
DRAM_CLK, DRAM_CKE : OUT STD_LOGIC;
DRAM_ADDR : OUT STD_LOGIC_VECTOR(11 DOWNTO 0);
DRAM_BA_0, DRAM_BA_1 : BUFFER STD_LOGIC;
DRAM_CS_N, DRAM_CAS_N, DRAM_RAS_N, DRAM_WE_N : OUT STD_LOGIC;
DRAM_DQ : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0);
DRAM_UDQM, DRAM_LDQM : BUFFER STD_LOGIC
END memTest;
ARCHITECTURE Structure OF memTest IS
COMPONENT niosII
PORT (
-- 1) global signals:
signal clk_0 : IN STD_LOGIC;
signal reset_n : IN STD_LOGIC;
-- the_button_pio
signal in_port_to_the_button_pio : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
-- the_lcd_display
signal LCD_E_from_the_lcd_display : OUT STD_LOGIC;
signal LCD_RS_from_the_lcd_display : OUT STD_LOGIC;
signal LCD_RW_from_the_lcd_display : OUT STD_LOGIC;
signal LCD_data_to_and_from_the_lcd_display : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0);
-- the_led_pio
signal out_port_from_the_led_pio : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
-- the_sdram_0
signal zs_addr_from_the_sdram_0 : OUT STD_LOGIC_VECTOR (11 DOWNTO 0);
signal zs_ba_from_the_sdram_0 : OUT STD_LOGIC_VECTOR (1 DOWNTO 0);
signal zs_cas_n_from_the_sdram_0 : OUT STD_LOGIC;
signal zs_cke_from_the_sdram_0 : OUT STD_LOGIC;
signal zs_cs_n_from_the_sdram_0 : OUT STD_LOGIC;
signal zs_dq_to_and_from_the_sdram_0 : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0);
signal zs_dqm_from_the_sdram_0 : OUT STD_LOGIC_VECTOR (1 DOWNTO 0);
signal zs_ras_n_from_the_sdram_0 : OUT STD_LOGIC;
signal zs_we_n_from_the_sdram_0 : OUT STD_LOGIC;
-- the_seven_seg_pio
signal out_port_from_the_seven_seg_pio : OUT STD_LOGIC_VECTOR (15 DOWNTO 0)
END COMPONENT;
COMPONENT sdram_pll
PORT(inclk0: IN STD_LOGIC;
c0: OUT STD_LOGIC;
c1: OUT STD_LOGIC);
END COMPONENT;
SIGNAL DQM : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL BA : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL pll_cl: STD_LOGIC;
BEGIN
nios_system: niosII PORT MAP (pll_cl, KEY(0), SWITCHES, LCD_EN, LCD_RS, LCD_RW, LCD_DATA,
LEDG, DRAM_ADDR, BA, DRAM_CAS_N, DRAM_CKE, DRAM_CS_N, DRAM_DQ, DQM, DRAM_RAS_N, DRAM_WE_N,
HEX);
neg_3ns: sdram_pll PORT MAP(CLOCK_50, DRAM_CLK, pll_cl);
END Structure;
Edit: Reset is set to KEY[0] which is a HIGH until pressed.
Same problem here... I've tried several ways to fix this but all worthless. Someone please help us!
I managed to fix this but I am not sure why it worked.
My solution was to build my sopc piece by piece and update the bsp in NIOS. E.g. start with cpu, memory, create NIOS. Next add SW pio, update NIOS, next add led pio, update NIOS, etc. However, the LCD will still not start up. I am able to use it using VHDL and the altera control panel. The binary counter works for LED, and 7-Seg display. Interestingly enough, SW0-3 do not do a thing either. This problem was not limited to the binary count example, others that used the LCD and online open source examples failed to work as well. I'm thinking of making a new post for this issue since my original post is now fixed.- Mark as New
if u have you worl with windows 7 run NIOS II as administrateur i have the same problem and i formate may pc to windows XP PACK 3 and it's work . i have an other problem now when i try to change the .hex for my memory chip which i generate ith matlab i have an error that the first line in .hex does not much with cheksum i don't know what can i do plz some one help me
