- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
is it possible to Boot and Configure Max10 FPGA ( 10M50SCE144A7G) from an external serial flash memory . Does Max10 support Active serial configuration?
from what I have read so far we can only boot the FPGA from the on chip flash? Correct me if I am wrong. I couldnt find it in any of the documents. Thanks for all the help in advance! Sharu- Balises:
- boot
- Intel® MAX® 10 FPGAs
Lien copié
1 Répondre
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
MAX 10 only support JTAG and JTAG in-system configuration. You can boot the FPGA from the on chip flash and you can do normal JTAG configuration on the FPGA too. I do not think MAX 10 supports AS configuration as it is not stated in the user manual. You can refer to this pdf for more information:
https://www.altera.com/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
