21615 Discussions
Building crossGcc / gcc tools for Windows?
I see on the nioswiki that there are instructions for building the crossGcc toolchain on Linux.
My toolflow is currently in Windows so I was hoping to compile crossGcc for Windows. I started with Nios II command shell, which comes with native gcc.
When I do a make, the configure hangs forever with:
finding the maximum length of command line arguments...
Has anyone tried compiling the crossGcc tools on Windows? Should I be using mingw, etc? Hopefully I don't have to jump through a ton of hoops!
I'm compiling the cross tools because I want to improve on the lack of Nios II micro optimizations in crossGcc.
Any info/suggestions greatly appreciated.
Thanks, Peter
Just in case someone tries to compile crossGcc under cygwin in the future (yes I know cygwin builds are not my first choice either), here's what I had to change to get it to compile:
In the file binutils/ltconfig, beginning at line 791:
while test "X"`$CONFIG_SHELL $0 --fallback-echo "X$testring" 2>/dev/null` = "XX$testring" && new_result=`expr "X$testring" : ".*" 2>&1` && lt_cv_sys_max_cmd_len=$new_result && test $i != 17# 1/2 MB should be enough do i=`expr $i + 1` testring=$testring$testring doneneeds to be changed to:
while test "X"`$CONFIG_SHELL $0 --fallback-echo "X$testring" 2>/dev/null` = "XX$testring" && new_result=`expr "X$testring" : ".*" 2>&1` && lt_cv_sys_max_cmd_len=$new_result && test $i != 11# PREVENT CYGWIN HANG, hopefully 11 iterations is still enough do i=`expr $i + 1` testring=$testring$testring done
