hello,
i have troubles with the ethernet bandwith and retransmissions (ack). after some diagnostic i think it is an timing issue.
the wire length from the fpga -> knz9031 is:
mil | mm | m | delay | delay | |
RX_DV | 1692,83 | 42,997882 | 4,30E-02 | 227,5E-12 | 228ps |
RX_CLK | 1649,35 | 41,89349 | 4,19E-02 | 221,7E-12 | 222ps |
RXD0 | 1684,72 | 42,791888 | 4,28E-02 | 226,4E-12 | 226ps |
RXD1 | 1648,24 | 41,865296 | 4,19E-02 | 221,5E-12 | 222ps |
RXD2 | 1681 | 42,6974 | 4,27E-02 | 225,9E-12 | 226ps |
RXD3 | 1677,12 | 42,598848 | 4,26E-02 | 225,4E-12 | 225ps |
TX_EN | 1625,87 | 41,297098 | 4,13E-02 | 218,5E-12 | 219ps |
GTX_CLK | 1629,75 | 41,39565 | 4,14E-02 | 219,0E-12 | 219ps |
TXD0 | 1633,94 | 41,502076 | 4,15E-02 | 219,6E-12 | 220ps |
TXD1 | 1657,65 | 42,10431 | 4,21E-02 | 222,8E-12 | 223ps |
TXD2 | 1657,33 | 42,096182 | 4,21E-02 | 222,7E-12 | 223ps |
TXD3 | 1655,12 | 42,040048 | 4,20E-02 | 222,4E-12 | 222ps |
all wires are the same length, in every wire is an 22r resistor. the design is bought and not designed by us.
i found the following knowledge base entry:
https://www.intel.com/content/www/us/en/support/programmable/articles/000079123.html
=> TX_CLK to TXD/TX_CTL output data delay is specified as -0.85 to 0.15 ns
Datasheet 9031:
For the receive path (KSZ9031RNX to MAC), the KSZ9031RNX adds 1.2 ns typical delay to the RX_CLK output pin, with respect to RX_DV and RXD[3:0] output pins.
We use kernel v4 with u-boot and devicetree, after a lot of measuring and test,
i got the best result with this skew timing:
&gmac1 {
status = "okay";
phy-mode = "rgmii";
/* 0 bis 900*/
rxd0-skew-ps = <420>;
rxd1-skew-ps = <420>;
rxd2-skew-ps = <420>;
rxd3-skew-ps = <420>;
rxdv-skew-ps = <420>;
txd0-skew-ps = <360>;
txd1-skew-ps = <360>;
txd2-skew-ps = <360>;
txd3-skew-ps = <360>;
txen-skew-ps = <360>;
/* 0 bis 1860*/
rxc-skew-ps = <1680>;
txc-skew-ps = <1740>;
max-frame-size = <3800>;
But how could i calculate the skew timing?
Which timing should be the best, with mathematics
链接已复制
Also, just to confirm- you have already adjusted the skew setting on the PHY and you have found the best result from there?
So now you want a method to calculate the best skew timing for confirmation? How did you know the adjustment gave the best result in the first place?
in the first run, we just try different values and measured the data rate.
afte we ve more concerned with the topic, we found the information about calculating the delay.
and now we are not sure how we get the values.
i think with all the information from the first post, it should be possible to get the best delay settings.
but the fpga need some special settings
thanks
Can you provide some updates?
I cannot get any confirmation with internal team on the best skew calculation.
But the normal practice is to start with measuring a working window, get the min and max skews then use the midpoint and fine tune it as you wish. I think you have done this already.
If it is working on the hardware then it should be fine.
Nurina
We have a simulation board skew tool, this could help you calculate the best skew. https://www.intel.sg/content/www/xa/en/support/programmable/support-resources/design-guidance/board-developer.html
Nurina
thanks again for your answer, but the skew parameter tool is only for the memory interface.
there is no option for the cyclone v and no option for the rgmii interface.
also it considered not the https://www.intel.com/content/www/us/en/support/programmable/articles/000079123.html from the cyclone v and the rgmii interface.
i thought there is an intel employee who know how to calculate the desired skew values for the rgmii interface? all neccessary information at post #1.
thanks again
