21613 Discussions
Calculation of Number of embedded multiplier
Operation: z<= a*b;
Therer are 2 cases below and I need someone to explain on how the number below obtained. Pls explain the reason there are uses of mixed sign, unsigned and signed multiplier since this is just a signed operation. thanks
Case1:
input signed [31:0] b;
input signed [31:0] a;
(*multstyle = "dsp"*) output reg signed [63:0]z;
Simple Multipliers (9-bit) 0
Simple Multipliers (18-bit) 4
Embedded Multiplier Blocks --
Embedded Multiplier 9-bit elements 8
Signed Embedded Multipliers 1
Unsigned Embedded Multipliers 1
Mixed Sign Embedded Multipliers 2
Variable Sign Embedded Multipliers 0
Dedicated Input Shift Register Chains 0
Case2
(*multstyle = "dsp"*) output reg signed [31:0]z;
Simple Multipliers (18-bit) 3
Embedded Multiplier 9-bit elements 6
Signed Embedded Multipliers 0
Since the device's multipliers can only handle 18x18 multiplications, larger multiplications are implemented using several partial multiplications, like you learned in school.
Thus, a full 32x32 multiplication requires 4 partial multiplcations. And since the signal is in the MSB, the other parts are handled as unsigned.
1st a[17:0] * b [17:0] - unsigned * unsigned
2nd a[31:18] * b [17:0] - signed * unsigned
3rd a[17:0] * b [31:18] - unsigned * signed
4th a[31:18] * b [31:18] - signed * signed
Thus, the mix you're seeing in the report.
As for case 2, since you're only keeping the result's 32 LSBs, the 4th term isn't needed.
