21584 Discussions
Can Cyclone IV PIO Banks at 1.8V Safely Drive 3.3V I2C ICs in Open-Drain Mode?
adamShiau
I’m using an FPGA Cyclone IV EP4CE30F23.
Some of the PIO banks are set to 1.8V, and I’m using an open-drain configuration to drive some I2C ICs that operate at 3.3V.
I’d like to know if this setup could damage the FPGA.
Also, where can I find the PIO voltage tolerance specifications?
Thank you!
AdamS
FvM
I'd refer to datasheet Table1–3. Recommended Operating Conditions for CycloneIVE Devices, Vi range -0.5 to 3.6 V for all VCCIO values.
Open drain means the pin is switched between tri-stated (input mode) and output pulldown. No clamping action involved. Therefore I expect your intended operation should work.
You'll generally take care for possible signal reflections exceeding the safe FPGA input voltage range. Because high level is only driven by I2C pull-up resistors, there's little risk of exceeding it, even with longer traces.
Frank
FvM
Frank
