21605 Discussions
Can i modify Transceiver Toolkit's GUI?
i would like to ask if there is any way to modify Transceiver's Toolkit Gui. Is there any access to its tcl script? For example i would like to add one more pattern (just like low and high frequency pattern) in pattern checker module which i would like to can be seen on the GUI.
Many thanks,
Evangelia
I believe it is not possible to edit the transceiver toolkit GUI. You might want to consider building your own pattern generator and checker and hook it up to the toolkit design.
