21615 Discussions
Can't Launch Eclipse
I have a fresh install of CentOS 5.6 and Quartus and Nios version 9.1 sp2. Quartus is running okay, but when I try to launch Eclipse I get this error. Can anyone offer insight on what this is?
!SESSION 2012-07-12 10:33:50.169 ----------------------------------------------- eclipse.buildId=M20080911-1700 java.version=1.6.0_14 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US Framework arguments: -perspective com.altera.sbtgui.ui.cPerspective Command-line arguments: -os linux -ws gtk -arch x86 -perspective com.altera.sbtgui.ui.cPerspective !ENTRY org.eclipse.equinox.p2.director 2 0 2012-07-12 10:33:52.684 !MESSAGE Problems resolving provisioning plan. !SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2012-07-12 10:33:52.684 !MESSAGE Unable to satisfy dependency from com.altera.sbtgui.feature.feature.group 9.1.0.222 to requiredCapability: org.eclipse.equinox.p2.iu/com.altera.debug.cdi.plugin/. !ENTRY org.eclipse.ui.workbench 4 0 2012-07-12 10:34:06.501 !MESSAGE Widget disposed too early! !STACK 0 java.lang.RuntimeException: Widget disposed too early! at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:171) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:117) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1163) at org.eclipse.swt.widgets.Widget.release(Widget.java:1026) at org.eclipse.swt.widgets.Control.release(Control.java:3221) at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:1184) at org.eclipse.swt.widgets.Widget.release(Widget.java:1029) at org.eclipse.swt.widgets.Control.release(Control.java:3221) at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:1184) at org.eclipse.swt.widgets.Widget.release(Widget.java:1029) at org.eclipse.swt.widgets.Control.release(Control.java:3221) at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:1184) at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:211) at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:466) at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1948) at org.eclipse.swt.widgets.Widget.release(Widget.java:1029) at org.eclipse.swt.widgets.Control.release(Control.java:3221) at org.eclipse.swt.widgets.Widget.dispose(Widget.java:442) at org.eclipse.swt.widgets.Shell.dispose(Shell.java:1893) at org.eclipse.swt.widgets.Display.release(Display.java:3083) at org.eclipse.swt.graphics.Device.dispose(Device.java:237) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:129) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at org.eclipse.equinox.launcher.Main.run(Main.java:1236) at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
