21615 Discussions
Can't connect to MAX10 custom PCB
Greetings,
We are working on our custom PCB with MAX10. Unfortunately, we are still unable to connect to this target from Quartus via USB-Blaster+JTAG (Auto-connect gives "Error: Unable to scan device chain. Can't scan JTAG chain").
We're using TerasIC USB-Blaster and we've checked that it's working just fine.
Here is a brief description of current debugging setup:
- FPGA Model
- 10M50SCE144C8G;
- Power Supply
- External (from 10M08 devkit) - 3.3 [V] to VCC_ONE (core) and all banks;
- Oscillator
- internal only;
- JTAG Configuration:
- TCK - tied to GND;
- TDI, TMS, JTAGEN - tied with 10k to VCCIOB;
- TDO - not connected;
- FPGA Configuration:
- DEV_CLRn, DEV_OE, nCONFIG, nSTATUS, CONF_DONE - through 10k to VCCIO;
- CONFIG_SEL, CRC_ERROR - not connected;
- PCB - Layers - 4;
- Soldering - Hot-air;
- Shortcut tested;
Considerations: After a couple of tests, we figured out that connecting TCK signal to FPGA pulls down rest of pulled up signals (TMS, TDI) - which is different from MAX10 devkit signals behaviour. Also CONF_DONE signal remains low (which indicates that FPGA is still in reset state).
Any ideas what to do/check next ?
