21615 Discussions
Can't connect to USB serial port with nios2-terminal
I have a Bemicro board, which includes a FTDI virtual com port, and I cannot connect to it using nios2-terminal under windows. The com port is COM4 and hyper-terminal works perfectly.
When I use "/dev/com4", nios2-terminal responds that there is no such file or directory. I checked and there is no "\dev" directory. I'm not sure if cygwin will handle this on the fly or not.
Can anyone help me out?
--- Quote Start ---
--- Quote End ---
Make
--- Quote Start ---
ls /dev/tty*
--- Quote End ---
and show result.
--- Quote Start ---
show result.
--- Quote End ---
Sorry, didn't work. Same error:
$ nios2-terminal --uart --port=/dev/tty4 --baud-rate=115200 nios2-terminal: can't open uart: No such file or directory I tried tty0 to tty5. I am trying to use COM4.
No "dev" directory.
$cd / && ls -a ./ COPYING.LIB* Cygwin.bat* bin/ etc/ tmp/ ../ COPYING.LIBGLOSS* Cygwin.ico* cygdrive/ lib/ usr/ COPYING* COPYING.NEWLIB* LICENSE.TXT* cygreg.bat* proc/ var/
