I use StratixII EP2S60 rohs, in my application i need to use 64 block of M4k. In my board i have 255 blocks. When i added to my SOPC the 64 blocks, and i start simulation he appear to me this 2 error:
1/ selected device has 255 ram location of types m4k. however the current design needs more then 255 to succesfully it. 2/ can't fit design in device. How can i resolve this problem please?Link Copied
change a device!
Redesign the RAM so it is more efficient.
Change the device, just to see if it solve your problem.
sds[]- Mark as New
Hi all,
I have exactly the same problem => I changed the device, and verified all settings.. but always the same error message when compiling "can't fit design in device" Any other suggestion please ?- Mark as New
Do you have some inefficient ram?
Fifo's often use more memory than one would expect. e.g. a Fifo of 1280 by 32 uses 16 M4k but only 40960 bits are used. If you split it into two concatenated Fifo's (building a compound Fifo) you can restrict the M4k usage to 10.
