Help please:
I try to install Quartus 14.1 web edition on a Windows 7 x64. However, I got this error when try to launch the quartus: quartus.exe: the application was unable to start correctly (0xc000007b). This is a newly installed Windows, quartus used to be working in my old system, but I just upgraded my HDD to SDD, and reinstalled the windows ... The windows 7 is just fully updated. Any help? or any idea how to track down the problem? ThanksLink Copied
OK. Version 13.0sp1 works.
HELP:
I have the same problem, but I have installed QuartusII 14.1 subscription edition, and when I try to launch quartus I get the error the application was unable to start correctly (0xc000007b). How did you solve this problem? Did you just install the Quartus 13.0sp1 or did you find a solution? Thank you --- Quote Start --- Help please: I try to install Quartus 14.1 web edition on a Windows 7 x64. However, I got this error when try to launch the quartus: quartus.exe: the application was unable to start correctly (0xc000007b). This is a newly installed Windows, quartus used to be working in my old system, but I just upgraded my HDD to SDD, and reinstalled the windows ... The windows 7 is just fully updated. Any help? or any idea how to track down the problem? Thanks --- Quote End ---- Mark as New
Try reinstalling the visual C libraries see http://www.microsoft.com/en-us/download/details.aspx?id=5555
I just simply use 13.0sp1 instead. please tell us if Galfonz's solution works for you.
--- Quote Start --- Try reinstalling the visual C libraries see http://www.microsoft.com/en-us/download/details.aspx?id=5555 --- Quote End --- SOLVED: Thank you Galfonz, I have reinstalled the Microsoft visual C++ libraires and now seems that Quartus works correctly!
