21615 Discussions
Can't load .jic file to cypress CFI FLASH.
ZNiu0
Hello, I am trying to load the .jic file to cypress FLASH ( S29GL01GS) with Quartus programmer but I fail. I wonder whether only the EPCS/EPCQ devices can be used to be loaded the .jic file or not. Can you give me some advice on load my application code into cypress FLASH? Thank you
JohnT_Intel
You will need to select the correct flash device when you are converting the sof to jic flash. Please use Quartus 18.1.1 Standard Edition and guide in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-gen-flash-programmer.pdf
