21608 Discussions
Can't resolve multiple constant drivers for net "next_state"
Dear Sir,
I am writing one simple program for traffic signalling.
I got the following error.
Error (10028): Can't resolve multiple constant drivers for net "next_state" at traffic.v(43)
can anyone help to solve this problem??
the code is below:
`define GREEN 0
`define YELLOW 1
`define RED 2
module traffic(R, G, Y, clock, reset);
output R, Y, G; // Red, Yellow, Green Signal lines
input clock, reset;
reg next_state;
reg R, Y, G;
always @(posedge clock)
begin
case (next_state)
`GREEN:
begin
next_state = `YELLOW;
G=1;
R = 0;
end
`YELLOW:
begin
next_state = `RED;
Y=1;
G = 0;
end
`RED:
begin
next_state = `GREEN;
R = 1;
Y = 0;
end
endcase
end
always @(reset)
next_state =`RED;
endmodule
This is slight modification of your code, it works, and is a different approach to writing state machines in verilog:
module Verilog_Traffic(R, G, Y, clock, reset);
input clock, reset;
reg R, Y, G;
//state machine parameters
reg [1:0] present_state, next_state;
parameter Green = 2'b00,
Yellow = 2'b01,
Red = 2'b10,
Reset_State = 2'b11;
always @ (posedge clock)
begin
if(reset)
present_state = Reset_State;
else if (~reset)
present_state = next_state;
end
always @ (present_state)
case (present_state)
Green:
begin
G = 1'b1;
R = 1'b0;
next_state = Yellow;
end
Yellow:
begin
Y = 1'b1;
G = 1'b0;
next_state = Red;
end
Red:
begin
R = 1'b1;
Y = 1'b0;
next_state = Green;
end
Reset_State:
begin
R = 1'b0;
Y = 1'b0;
G = 1'b0;
next_state = Red;
end
endcase
endmodule
you'll need to change the line "module Verilog_Traffic" to "module traffic"...sorry about that.
I think the reason for the error message is that there are two events which can affect the value of nextstate which are not mutually exclusive. Consider what would happen if there was a positive edge on clock at the same time that reset changed. What would nextstate become?
I'd use a synchronous reset, i.e.
if(reset)
begin
// Reset nextstate
end
else
begin
// State machine case statement
end
If you re-order your code in this way you might find it works.
Hi, thanks for clearing my mind about this error. My fsm compiled and simulate success in modelsim but switch to quartus it shows this error. Cheers
