21588 Discussions
Cannot merge HSSI Avalon Memory-Mapped interface instances for simplex JESD designs
cheyert
When instantiating simplex Rx and Tx JESD cores generated by quartus, and enabling the reconfiguration interfaces, the following placement error shows:
Error (12829): Failed to merge HSSI Avalon Memory-Mapped interface instances "main|devices[0].jesd204_rx_core|main|intel_arria_10.unit|intel_jesd204_core|jesd204_core|jesd204_0|inst_phy|inst_xcvr|g_xcvr_native_insts[1].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" and "main|devices[0].jesd204_tx_core|main|intel_arria_10.unit|intel_jesd204_core|jesd204_core|jesd204_0|inst_phy|inst_xcvr|g_xcvr_native_insts[1].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" into single Avalon Memory-Mapped Interface.
The error is also described here, albeit for a different IP, but still the error is the same..
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ip/2020/error-12829---failed-to-merge-hssi-avalon-memory-mapped-interfac.html
Another similar issue is here, which does seem to have a workaround
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd09282014_173.html
So is there a workaround for my case as well, or is upgrading to latest quartus really necessary, and how do I know that this will in fact solve the issue without having to upgrade the entire design?
CheePin_C_Intel
Thanks for your update. Please allow me some time to further look into this. Just to check with you if your design changing to 1 lane, can the merging successful? Just to help narrowing down if it is related to the number of lanes configured in the IP.
Thank you.
CheePin_C_Intel
Just would like to follow up with you on this. Thank you.
CheePin_C_Intel
As I understand it, it has been some time since I last heard from you. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
cheyert
I would like to keep this open because as to date I have no resolution to this issue yet.
I'm pretty sure I've exhausted all options as mentioned in the discussion, so not sure how to proceed from here on this issue.
CheePin_C_Intel
Just to check with you if you have had a chance to try with my previous 2 lanes design which mimic your configuration?
Please let me know if there is any concern. Thank you.
Chee Pin
cheyert
I'll try to provide feedback on this tomorrow, I compared the design for settings which all seemed correct, but haven't gone though fitting yet, will attempt tomorrow
