21604 Discussions
Cannot obtain IP address of SoC Cyclone V using SD image from OpenCL SDK 17.1
I am trying to establish connection between host and board via ethernet but I cannot obtain IP address of the SoC Cyclone V board. I am using the latest SD image from Intel FPGA OpenCL SDK 17.1 .I've also managed to compile and run some design examples using OpenCL. When it's booting the image I get this error message:
Sending discover...
libphy: stmmac-0:04 - Link is Up - 1000/Full
Sending discover...
Sending discover...
No lease, failing
Also on the LCD it shows: '"No IP obtained Hello Tim"
I've also tried GSRD 17.1 image from rocketboards.org and I can obtain IP address successfully. However, I need OpenCL compatible SD image. Are there any quick fixes or I'll need to install OpenCL on GSRD 17.1 image?
