20792 Discussions
Cannot use command line in linux
when i try to use command line in linux envioment with Quartus10, the following message has occour even I setenv for the PATH/SCRIPT_PATH with /opt/quartusII_10.0_local/quartus/bin:
> quartus_map filtref --source=filtref.bdf --family=CYCLONE
/opt/quartusII_10.0_local/quartus/bin/quartus_map: SCRIPT_PATH=/opt/quartusII_10.0_local/quartus/bin: is not an identifier
i haven't set SCRIPT_PATH before, can you show where in the documentation it shows setting this variable?
I just try to set this varible in Linux. where could you run quartus TCL command? Maybe this can give some hint. Thanks.
