Hello, Now I have one more question, I wanna know about the usb blaster, i will buy DE2, then i wanna know if usb blaster will come with the board, or i need to buy separate.
So, if usb blaster doesn't come with the board, i need to buy, or i can program the fpga with usb port. Thanks for all :cool:Link Copied
The kit doesn't come with a separate USB blaster, but the blaster logic is directly embedded on the board. Just connect the USB cable to your PC and the board will be detected as a USB baster. Nothing more needed.
But can i program only with usb that the board has?
yes you can
