21615 Discussions
Comparing two ring oscillators in FPGA for RO PUF
i'm doing a project on Ring Oscillator PUF to implement on FPGA. In my design, i have compared 2 ROs to see which RO is faster. When the first RO is faster than the second RO, the output bit will be 1 and if slower wil be 0. I have manually placed the ROs on the chip so that i'm using the same ROs everytime after compilation.
However there is a problem with the design, the output is very unstable. :(
Does anyone have any idea, how i can make sure the frequency cycle produced by the RO stable?
How do you determine "unstable"?
Are you sure your design is able to compare asynchronous clocks?
Thank you for your reply.
What i meant by unstable was, when i compare both ROs the output is sometimes '1' and sometimes '0'.
For example, when tested the chip 10 times, the chip produced output '1' 6 times and '0' 4 times.
I would like the design to produced only '1' or '0' 9 times when i test it again 10 times.
I use counter to count the frequency of the RO and it is asynchronous. Does this mean that my design is able to compare asynchronous clocks?
What I meant is that when comparing RO clock with reference clock or both RO clocks, domain crossing techniques must be applied.
But the "unstable" result may be just a result of the RO output jitter.
I resolved my problem. It was the counter, i did not set the maximum limit. A very stupid mistake.
Thank for your reply. :)
