21584 Discussions
Compile Error when using one inclock for SERDES IPs in different I/O banks
Jens
I'm using a Arria 10AX048H4F34E3SG device for interfacing an image sensor. The serial LVDS data channels from sensor are connected to 6 I/O banks. The serial data clock is just within one I/O bank. I have 6 SERDES IPs instantiated which should use this clock as inclock. The Quartus Fitter generates this error for the channels which are not in the same I/O bank like the clock:
Error (175006): Could not find path between source IOPLL and the LVDS_CHANNEL
Is there any option to avoid this error?
I tried using an external PLL for the SERDES but it produces the same error.
Jens
AminT_Intel
Hello Jens,
You might get this error because LVDS IOPLL clock is driven across multiple banks in Arria 10.
All RX channels need to be in one I/O bank and each I/O bank can support up to 24 channels for LVDS SERDES IP Core Functional Modes.
You can refer to page 4, 13, 31 and 37 document on this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altera_lvds.pdf
I hope this answer helps.
