here is an instance from a scfifo in verilog scfifo the_user_to_master_fifo ( .aclr (reset), .clock (clk), .data (user_buffer_data), .full (user_buffer_full), .empty (user_buffer_empty), .q (master_writedata), .rdreq (read_fifo), .wrreq (user_write_buffer) ); defparam the_user_to_master_fifo.lpm_width = DATAWIDTH; defparam the_user_to_master_fifo.lpm_numwords = FIFODEPTH; defparam the_user_to_master_fifo.lpm_showahead = "ON"; defparam the_user_to_master_fifo.use_eab = (fifousememory == 1)? "on" : "off"; defparam the_user_to_master_fifo.add_ram_output_register = "OFF"; defparam the_user_to_master_fifo.underflow_checking = "OFF"; defparam the_user_to_master_fifo.overflow_checking = "OFF"; and here in VHDL: scfifo_component : scfifo GENERIC MAP ( add_ram_output_register => "OFF", intended_device_family => "Cyclone III", lpm_numwords => fifo_depth, lpm_showahead => "ON", lpm_type => "scfifo", lpm_width => 8, lpm_widthu => fifo_depth_log2, overflow_checking => "ON", underflow_checking => "ON", use_eab => "on" ) PORT MAP ( clock => clock, sclr => sclr, wrreq => wrreq, aclr => aclr, data => data, rdreq => rdreq, usedw => sub_wire0, empty => sub_wire1, full => sub_wire2, q => sub_wire3 ); Now my question: Can i use conditional signal assignments for "actuals" in generic maps in VHDL likedefparam the_user_to_master_fifo.use_eab = (fifousememory == 1)? "on" : "off"; in Verilog ? I have tried use_eab => ("0n" when (fifo_use_memory = 1) else "off")
but this doesent work. Thanks, Nicolas
I too have longed for such a 'ternary' statement in VHDL for a long time. Until it dawned upon me that I could write a function to achieve the effect. Here is one of my functions:
function ternary( f , s : integer ; condition : string ; tr , fr : string )
return string
is
begin
if (condition = "EQ" ) then
if ( f = s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "GT") then
if ( f > s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "GTE") then
if ( f >= s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "LT") then
if ( f < s ) then
return tr ;
else
return fr ;
end if ;
elsif (condition = "LTE") then
if ( f <= s ) then
return tr ;
else
return fr ;
end if ;
end if ;
end function ternary ;
In your case you would use this as follows :
use_eab => ternary( FIFOUSEMEMORY , 1 , "EQ" , "ON" , "OFF") ,
May look a bit contrived, but it works! VHDL handles 'overloading' so I wrote a few variants of the 'ternary' function to cover for other input parameters and return values.
Thanks for your reply,
Great idea with the function. I now have written the function:function fifo_use_eab ( use_eab : boolean ) return string is
begin
if (use_eab = true) then
return "ON";
else
return "OFF";
end if ;
end function fifo_use_eab;
Now i can use the function as "actual" in the generic map during the component instantiation in my code. scfifo_component : scfifo
generic map
lpm_width => 8,
use_eab => fifo_use_eab (fifo_use_memory)
port map
clock => clock,
sclr => sclr,
wrreq => wrreq,
aclr => aclr,
data => data,
rdreq => rdreq,
usedw => usedw,
empty => empty,
full => full,
q => q
That is quiet the thing.
